A/C Compressor will not turn on
2004 GMC ENVOY
175,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
CSUNDE1953
  • 13 POSTS
Installed new compressor charge system but AC clutch won’t engage.
May 15, 2022 at 3:12 AM
There is a fuse #30 (10 amp) in the under-hood fuse panel let's check it for power. here is a guide to help and the fuse location along with the wiring diagrams for the A/C compressor so you can see how the system works:
May 16, 2022 at 9:33 AM
CSUNDE1953
  • 13 POSTS
I just checked all the fuses, and they are good, then they unplugged the relay plugged it back in and I felt a click, I looked down at the compressor pulley and it is running but very slowly.
May 17, 2022 at 3:09 PM
CSUNDE1953
  • 13 POSTS
When I unplugged the relay, the compressor completely stops.
May 17, 2022 at 3:10 PM
Okay, so lets pull the plug on the compressor and measure the voltage to the compressor with the system on it should be 12 volts. One wire will have no voltage. This guide can help you with the test.
May 17, 2022 at 5:15 PM
CSUNDE1953
  • 13 POSTS
Okay, here’s an update: I check the voltage on the plug at the compressor dark green wire has 14 V the light green wire has 1.12 V.
May 18, 2022 at 6:24 AM
CSUNDE1953
  • 13 POSTS
That's with the engine running.
Good job. Now let's check the ground circuit (black wire). It is connected to the body near the fuse panel. You can do an OHMs check. If this is okay, you got a bad compressor. Can I ask which brand the compressor is?
May 18, 2022 at 11:30 AM
CSUNDE1953
  • 13 POSTS
It is a RYC remanufactured compressor.
May 18, 2022 at 11:40 AM
CSUNDE1953
  • 13 POSTS
Is the third wire on that compressor connector the ground the black wire.
May 18, 2022 at 12:31 PM
Yes, it is, I would have used an AC Delco compressor. The quality of some rebuilds are questionable.
May 19, 2022 at 10:14 AM
CSUNDE1953
  • 13 POSTS
Lesson learned. I just want to say thank you very much for all your help.
May 19, 2022 at 7:08 PM
Good to hear, please use 2CarPros anytime we are here to help.
May 20, 2022 at 7:19 PM
