A/C COMPRESSOR REPLACEMENT?
1998 PLYMOUTH NEON
185,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
REDCRU777
  • 84 POSTS
My '98 2.0L sohc 4 door Neon needs the A/C compressor replaced. I need help to do this, it would be my first time to do this, May I request for info (guide/instructions) on how to do this correctly?
Thanks a lot. Rey
Jan 29, 2023 at 10:29 AM
Sure, we can help, here is a video to help vacuum down and recharge the system with a generic guide to help you step by step and I have included the instructions for your car in the images below.
https://youtu.be/4EqdrBVb0sY
and
https://www.2carpros.com/articles/replace-air-conditioner-compressor
CAUTION: Add only new lubricant when system requires additional lubricant. Do not use old reclaimed lubricant.
REMOVAL
The A/C compressor may be unbolted and repositioned without discharging the refrigerant system. Discharging is not necessary if removing the compressor clutch/coil assembly, engine, cylinder head, or alternator.
WARNING: REFRIGERANT PRESSURES REMAIN HIGH EVEN THOUGH THE ENGINE MAY BE TURNED OFF. DO NOT TWIST OR KINK THE REFRIGERANT LINES WHEN REMOVING A FULLY CHARGED COMPRESSOR. SAFETY GLASSES MUST BE WORN.
1. Disconnect battery negative cable.
2. Loosen and remove drive belts.
3. Using a R-134a refrigerant recovery machine, remove the refrigerant from A/C system. If the compressor is being replaced.
4. Disconnect compressor clutch wire lead.
5. Remove refrigerant lines from compressor, if necessary.
6. If system is left open place plug/cap over open lines.
7. Remove compressor attaching bolt.
8. Remove compressor. If refrigerant lines were not removed, lift compressor/clutch assembly and tie it to a suitable component.
INSTALLATION
- For installation, reverse the above procedures.
Search vehicle information
Community 8 Create Quote
1998 Dodge Neon L4-2.0L VIN C
A/C Compressor
Vehicle Heating and Air Conditioning Compressor HVAC Description and Operation Components A/C Compressor
A/C COMPRESSOR
SYSTEM OPERATION
The compressor used on this vehicle is a Nippondenso 10PA17 R-134a. This compressor uses an aluminum swash plate, Teflon coated pistons and aluminum sleeved cylinder walls.
CAUTION: A 10PA17 R-12 compressor looks identical to a 10PA17 R-134a and will bolt up to the vehicle. The 10PA17 R-12 compressor must not be used on this system. It is extremely important that a 10PA17 R-134a compressor is identified prior to using compressor in question. Check tag located on compressor for model number.
Noise
Excessive noise that occurs when the air conditioning is being used may be caused by:
- Loose bolts
- Mounting brackets
- Loose compressor clutch
- Excessive high refrigerant operating pressure
Verify the following before compressor repair is performed:
1. Compressor drive belt condition
2. Proper refrigerant charge
3. Thermal expansion valve (TXV) operating correctly
4. Head pressure is normal
Compressor Front Shaft Seal
The compressor front shaft seal is not serviceable. If a leak is detected at the shaft seal, the compressor must be replaced as a unit.
Please let us know if you need anything else to get the job done.
Jan 29, 2023 at 6:40 PM
REDCRU777
  • 84 POSTS
Hi Ken,
Thanks a lot for your very detailed reply, I highly appreciate it.
I'll start working on it ASAP. I'll keep you posted.
Many thanks again.
More power to 2CarPros!
Rey
Feb 2, 2023 at 1:33 PM
Please let us know if you need anything else to get the problem fixed. We are glad to help.
Feb 3, 2023 at 1:20 PM
REDCRU777
  • 84 POSTS
Hi Ken,
The new 10PA17 R-134a compressor doesn't have any info on how much oil (PAG 46) is needed for the compressor.
Please advise.
Thanks.
Rey
Feb 7, 2023 at 6:57 PM
Here is the refrigerant oil volume information. The compressor usually takes about 2.5 ounces but it should come with oil in it already.
CAUTION: The refrigerant oil used in a R-134a A/C system is unique. Use only oils which were designed to work with R-134a refrigerant. The oil designated for this vehicle is ND8 PAG (polyalkalene glycol).
Recovery/recycling equipment will measure the lubricant being removed. This is the amount of lubricant to be added back to the system. If a new compressor is being installed, drain lubricant from old compressor, measure the amount drained and discard old lubricant. Drain the lubricant from the new compressor into a clean container. Return the amount of lubricant measured from the old compressor, plus the amount reclaimed from the system back into the new compressor.
1. Discharge refrigerant system using recovery/re-cycling equipment if charge is present.
2. Disconnect refrigerant lines from A/C compressor. Cap the open lines to prevent moisture from entering system.
3. Remove compressor from vehicle.
4. From suction port on top of compressor, drain lubricant from compressor.
5. Add system capacity minus the capacity of components that have not been replaced.
- Total System 200 ml (6.75 oz)
- Filter-Drier 30 ml (1.0 oz)
- Condenser 30 ml (1.0 oz)
- Evaporator 59 ml (2.0 oz)
- All refrigerant lines 44 ml (1.5 oz)
Add lubricant through the suction port on compressor. This is not to exceed 200 ml (6.75 oz.) in total.
6. Install compressor and connect refrigerant lines. Then evacuate and charge refrigerant system.
Feb 9, 2023 at 9:38 AM
REDCRU777
  • 84 POSTS
Hello Ken,
Thank you for the info.
By the way, I am replacing the evaporator as well, can you please provide me the guide on how to go about it?
Thank you so much!
Rey
Feb 9, 2023 at 2:11 PM
Sure, can you please start a new question for this? Please post your new question here, you must be logged in.
Feb 10, 2023 at 1:21 PM
