Hi Rudyc,
I attached all the appropriate documents including the process on how to balance the oil in the system. Please let me know if you need any more info. Also, just want to make sure you are performing an evacuation/recovery of the system before you take the compressor off and then again, with the new compressor so you get all the air and moisture out of the system and check for leaks with pulling it into a vacuum.
Also, just make sure you are measuring the amount of oil you are taking out of the old compressor because if it is more than the specified amount, then you need to use that.
https://www.2carpros.com/articles/replace-air-conditioner-compressor
Let me know if you have more questions. Thanks
May 26, 2019 at 11:00 AM
