The 1999 Ford F-250 7.3L Powerstroke is one of the easiest trucks to bypass the A/C compressor on, because Ford actually designed the belt layout in a way that lets you run a shorter serpentine belt with no change to the routing.
Serpentine belt: 98.0" length (approx. 2490 mm)
Common part numbers:
Gates K080975
Dayco 5080975
Motorcraft JK8-978
These all fall in the 97.5 - 98.0" range and work perfectly.
Please use 2CarPros anytime we are here to help.
Nov 18, 2025 at 12:27 PM
