Okay, Let me start over, I have had my vehicle to shops. Not a whole lot was resolved. It appears I have a ground problem, that was the answer from the A/C shop. The electrical auto guy says it is a thermostatic meter. Let me just reiterate, I did find a wire crossed at pressure switch to make the compressor run 100% of the time (fixed) The compressor, pressure switch, expansion valve, dryer have all been replaced, system has been evacuated, flushed, but the pressure is running to high on the high side. The cycling time is not right.
My understanding is the signaling for it to go from high to low cycling is not right. Can someone tell me a common reason for this? might add the relay has been checked and it shows that if you ground it the compressor kicks on when its not on. Maybe this is a clue.
Signed, in over his head.
May 16, 2018 at 12:14 PM
