Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Chevrolet
Cavalier
Climate Control
Air Conditioner
Compressor
Clutch
A/C clutch stays engaged
2003 CHEVROLET CAVALIER
120,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
WRECKDIVER230
MEMBER
FOLLOW
Does not cycle , does shut off when fuse is pulled , Freon is okay , using single hose type gauge.
Jul 17, 2019 at 11:22 AM
CERTIFIED EXPERT
Good afternoon,
Is the air cool in the car?
I need to see both pressures to see if the system is working correctly. You can rent a set of gauges at a parts store.
https://www.2carpros.com/articles/how-a-car-air-conditioner-works
The system may not cycle depending on ambient air temperature.
Jul 17, 2019 at 12:36 PM
WRECKDIVER230
MEMBER
i just ordered a new set of gauges, will check back when they arrive. ambient air was 113 degrees.
Jul 17, 2019 at 12:38 PM
CERTIFIED EXPERT
Okay, sounds like a plan.
Jul 17, 2019 at 12:40 PM
WRECKDIVER230
MEMBER
Okay , got new set of gauges. here are results: ambient temperature 102 degrees
engine off pressures low 100,
high 90
engine on low 90
high 100
clutch runs constantly , will shut of with switch or pulling fuse,
i believe its a bad compressor ,
Jul 21, 2019 at 1:38 PM
CERTIFIED EXPERT
You are correct. The pressures did not budge at all.
Replace the compressor, dryer and expansion valve.
https://www.2carpros.com/articles/replace-air-conditioner-compressor
Jul 21, 2019 at 1:57 PM
