A/C blowing hot air?
2005 GMC CANYON
86,000 MILES • 3.5L • 5 CYL • 4WD • AUTOMATIC
ALLEN WILSON
  • 5 POSTS
A few days ago, the A/C would intermittently cut off and only blow on high. After some research I changed out the blower motor resistor, old one had a burnt contact. Fixed that issue. Two days later it would only blow hot air. I don't know if it's a related issue or not but when the A/C started blowing hot my radio quit working. I pulled and put back the fuse for it and it came back on.
Please help it's hot and I spend a good amount of time in my truck.
Thanks
Aug 5, 2022 at 12:57 PM
Allen,
When you removed and reinstalled the fuse, did the A/C start working again, or was it the radio?
If the A/C still isn't working, I need you to check something for me. When you turn the A/C on, the A/C compressor clutch should engage. When this happens, you will hear a click, and the center of the compressor pulley will engage and spin. See if that is happening and let me know.
Also, take a look through this link. It may be helpful.
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
Aug 5, 2022 at 8:40 PM
ALLEN WILSON
  • 5 POSTS
The radio is what started working again. I noticed yesterday evening that while driving it would get cooler for probably 5 to 10 seconds and that only happened twice in a 10-mile drive. I'll do that test with me looking in the engine bay later today when I can get to it.
Aug 6, 2022 at 9:10 AM
It could simply be a low-charge issue. Let me know what you find.
Aug 6, 2022 at 7:04 PM
ALLEN WILSON
  • 5 POSTS
I tried to add refrigerant. When I hooked it up it showed at the very bottom of the green so I tried to add some, it seemed like it wouldn't take any, the needle wouldn't come up at all then the compressor would surge, and the needle would jump to the high side of the green and then fall right back to the low side of the green.
Aug 8, 2022 at 7:40 AM
When you say the compressor would surge, do you mean it would kick on and off?
At this point, I really suggest checking both the low and high sides pressures using a manifold kit.
Take a look through this link. It explains what I am suggesting.
Aug 8, 2022 at 8:45 PM
ALLEN WILSON
  • 5 POSTS
I took it by a local shop this morning. I don't have all the gauges I would have needed to check. It ended up being a leaky valve. They replaced the valve and refilled the refrigerant. It cost me $210.
Thanks for all your help.
Aug 9, 2022 at 10:50 AM
Thank you for the update. Was it the Schrader valve that was leaking? Also, is it working properly for you now?
Aug 9, 2022 at 12:37 PM
ALLEN WILSON
  • 5 POSTS
He said it was on the high side. He didn't mention Schrader valve by name. It's working perfectly now.
Aug 9, 2022 at 1:57 PM
Hi Allen, that makes sense. Regardless, thanks for the update. I'm glad it's working again.
Please feel free to come back anytime in the future. You are always welcome here.
Take care of yourself.
Aug 9, 2022 at 7:40 PM
