A/C blowing hot air
2016 LINCOLN MKX
85,000 MILES • 2.0L • 2WD • AUTOMATIC
LESLIEANN707
First my car is an MKC not on list provided so I marked MKX. My air is blowing hot air. I bought A/C PRO and when I put tester on it went straight to the red which says see service tech.
Jul 11, 2019 at 4:37 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Are you saying the A/C is overcharged with R134A?
Jul 11, 2019 at 5:11 AM
Good morning,
Does the compressor turn on when you command A/C?
You need a set of gauges to give me the high and low side readings so I can see the readings.
Do you have a test light or voltmeter to check voltages for the system?
I attached a wiring diagram for you to view. Check the fuses for power on both sides with the key on.
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
Jul 11, 2019 at 5:14 AM
LESLIEANN707
Thank you for your help.. but sadly enough I'm having to have everything replaced a nice two grand. But I live in TN and can't live without air! Thanks again for your help!
Jul 18, 2019 at 5:17 AM
What was determined the failure?
Jul 18, 2019 at 5:20 AM
LESLIEANN707
I guess the compressor went out and in turn deteriorated everything else.. maybe the clutch froze up. It just seems to me that a car only 3 years old should of lasted longer. We turned it into the Ford dealer (probably while it's so expensive).
Jul 18, 2019 at 5:26 AM
Yes, I agree. Any repair shop would do this repair for way less. The compressor, dryer and expansion valve with labor should be around $1,200.00 to $1,300.00 out the door.
Jul 18, 2019 at 5:28 AM
