a/c blowing hot air
2005 NISSAN ALTIMA
160,000 MILES
KELLY030
My freon is full but when I turn my a/c on it blows warm air. Then it may kick on to cold after a while, then kick back to warm. Someone told me it sounds like it is short cycling..what do I need to check and replace? I have already replace the low pressure valve.
Apr 30, 2013 at 12:44 PM
KHLOW2008
  • 41,814 POSTS
This sounds like a classic compressor clutch problem. Here are a guide to help you confirm the problem.
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
and if so
https://www.2carpros.com/articles/replace-air-conditioner-compressor
Cheers,
May 25, 2021 at 11:28 AM
KELLY030
The a/c compressor is disengaging , and it is not switching to heat. Thanks for the guide I tested for power at the compressor and there was. Then replaced the compressor and it is all fixed, I love this site!
BOULDER40MMA
I am having this issue with my wife’s 2006 Nissan Altima. 2.5liter. The compressor clutch is engaging and it shows it has Freon. The valve shows red and the can says that means there’s an issue. It won’t take any Freon and it’s not freezing up. It worked for her in the morning then she left after a couple of hours and it only blew hot air. Is there any fuses I should check?
The clutch is turning on can you tell? Here is a guide to help you see if the clutch is turning on:
BOULDER40MMA
My clutch is spinning and engaging.
Okay, now we need the high side pressure reading when the system is running. here is a guide to help you see how the system should be working:
High side should be about 235 psi.
