There is a chance the blend air door (air mix door) actuator is not working. This actuator is what determines the air temperature entering the vehicle.
What I would suggest is to remove it from the HVAC box and while it's still connected to power, see if it responds when you change from hot to cold on the controller.
This actuator is behind the glove box. If you look at pic 1 below, I highlighted the actuator. Pic 2 includes the directions for removal and replacement.
The last two pics show how the glove box is removed.
Note that I am basing this on a manual system. If this vehicle has dual climate control and automatic temp control, let me know.
Also, here is a link you may find helpful. It explains how to replace a blend air door in general. I'm adding it because the directions from my manual are somewhat vague.
See pics below.
Jun 13, 2021 at 9:40 PM
