I just installed a new factory blend door actuator, which is located inside the glove box. Since i was getting hot air, now it's okay, and getting the A/C cold air i needed. But it seems to me that air flow from the vents is very low. I replaced the blower motor, HVAC switch resistor and all the vacuum lines inside the engine. I also have a 2000 Blazer and that blower motor blows air like a giant fan wind mill and I can see the difference in the other compared to this 2004. Is it possible that a door is broken or stuck? do i have to pull the dash to inspect this if i do? I can do this if need be, since i already replaced the heater core, what a job. Thanks for any info you can pass on and God bless all the info you pass on to all the people that write to you all.
Jun 14, 2024 at 11:18 AM
