A/C blinking?
1999 TOYOTA PREVIA
60,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
FABIEN.LEMARCHAND
  • 5 POSTS
Hi everyone,
I have an air conditioning problem on a Toyota Picnic 2.0gl 1999.
The problem seems specific to this model, as electric trouble.
Everything has been checked by a pro, and no result...
One member of this forum changed the entire fuse box, and it worked...
Which fuse box? Under the hood, or inside driver or Passenger side?
Thanks,
Fabien
Sep 10, 2022 at 4:28 AM
I believe I responded to the other post regarding this. Also, the vehicle he indicated was a different model. However, the fuse box that was replaced held the A/C relay and the A/C condenser fan relay. That is the best I can tell you. I wish I had more, but this model isn't offered in the US, so I don't have the specifics.
By chance, do you know which of the fuse/relay boxes holds those relays? I can tell you that most times, the box holding these is located under the hood. Check there and see if they are identified.
Sep 10, 2022 at 7:56 PM
