switching from front vent, defroster, feet, does not correspond?
2015 LEXUS IS 250
117,700 MILES • 2.5L • 2WD • AUTOMATIC
SIXTY6GTO
  • 95 POSTS
The air conditioning works but switching from front vent, defroster, feet, etc does not correspond with the input to the controls. Also this problem does not allow full control of the temperatures. Is there a blend door? Is there something else? What are common problems and items to check first? I attached a picture of the type of controls on this vehicle.
Jan 10, 2026 at 9:15 PM
Yep, this happens when the air mix actuator goes out which is common, here is the location and calibration instructions have the replacement. Here is how to rest the system once the repair are made
https://www.2carpros.com/articles/step-by-step-guide-to-reset-your-cars-hvac-system-an-essential-for-every
Check out the images (below). Please upload an image or a short video in your response. Ken
Jan 11, 2026 at 11:02 AM
SIXTY6GTO
  • 95 POSTS
Any chance there are service manual written procedures and video to change the air outlet control servo and the air mix control servo specifically on this make model ? That would be much appreciated.
Jan 11, 2026 at 1:32 PM
This is all we have, they don't give us step by step for some reason on this repair. Sorry. If you upload images for what you are doing to can help guide you through the repair.
Jan 12, 2026 at 11:30 AM
SIXTY6GTO
  • 95 POSTS
How to access the air mix control servo motor? I'm having a hard time to try and understand where its located and how to access it.
Mar 4, 2026 at 8:20 PM
SIXTY6GTO
  • 95 POSTS
I noticed that the modes are not corresponding as well. the face, feet , defrost etc does not correlate to the selection buttons . Mode servo?
Mar 4, 2026 at 8:29 PM
Yep, mode servo, it is located right above the accelerator pedal. Use a flash light so you can get at it, also remove the lower dash panel on the drivers side.
Mar 5, 2026 at 8:44 AM
SIXTY6GTO
  • 95 POSTS
There are two control servo motors in the picture. Can you explain the purpose of each of them? Since I know I definitely have a problem with the location of the air coming out of a different vent than selected, I should try to change that first.
The one with the red arrow is the air mix control servo motor, and what does that do? Also, the other one, the air outlet control servo motor pictured above it, what does that do?
Mar 6, 2026 at 7:51 AM
Yep, so the air mix is for the temperature and the outlet is for the vent control, ie: floor, mid and defrost.
Mar 6, 2026 at 8:41 AM
