a/c and heat will not blow out on high only
1999 GMC SAFARI
200,000 MILES • 4.3L • V6 • RWD • AUTOMATIC
AMBAM2015
So when I turn on either heat or air and adjust speed (low med low med high) all functions work beside the high setting. it blows on low and med not high. Is this the relay to the motor? Could it be the control switch in the dash? Also I only get air out of the defrost?? Please help. Single mother
Jul 19, 2015 at 2:52 PM
WRENCHTECH
  • 20,761 POSTS
It's most likely none of those things. The most likely cause is the blower resister, mounted next to the blower motor
Jul 19, 2015 at 3:24 PM
