A/C and heat only blows from the defroster and not the vents
2004 FORD CROWN VICTORIA
130,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
KEYREED
Also, my temperature button does not control the heat or A/C only blows heat mostly.
Apr 4, 2020 at 5:05 AM
Good morning,
The system works on both vacuum motors and electronic actuators.
https://www.2carpros.com/articles/air-vents-stay-in-the-defrost-position
The fact it is stuck in defrost mode tells me there may be either a vacuum supply issue or the vacuum motor on the heater case is bad. You will need to check for vacuum to the system from under the hood. I attached a vacuum diagram for you to view to be sure there is vacuum.
If it is the motor in the case, the instrument cluster has to be removed. That will be a large project.
Apr 4, 2020 at 5:28 AM
