A/C and dash lights
2006 NISSAN MAXIMA
120,000 MILES • V6 • 2WD • AUTOMATIC
MRCYCLOPZ
  • 4 POSTS
A/C does not start, and radio hub has no power to it. also, the dash lights will not turn on. Any help would be greatly appreciated! We just recently replaced the battery due to the car not starting up.
Nov 1, 2017 at 9:03 PM
KHLOW2008
  • 41,814 POSTS
Start with checking the fuses. One or more could have blown.
Nov 2, 2017 at 8:11 AM
MRCYCLOPZ
  • 4 POSTS
Thanks for the quick response! Fuses are fine none are blown.
Nov 2, 2017 at 12:38 PM
KHLOW2008
  • 41,814 POSTS
At the battery, ensure all wires were reattached. Check for loose connections and at under hood fuse box. Have you checked all the fuses and under dash fuse box?
You would need to check why power supply is missing.
Nov 2, 2017 at 7:58 PM
MRCYCLOPZ
  • 4 POSTS
I will do that now thanks!
Nov 2, 2017 at 8:20 PM
Nov 3, 2017 at 3:57 PM
MRCYCLOPZ
  • 4 POSTS
Dashboard and radio is back now but a.c. is still off
Nov 4, 2017 at 11:33 AM
There are more fuses to check and you will need to see what is loosing power or if it is the ac compressor itself. Here is a wiring diagram and a guide to help you do some simple testing.
and
Here are some guides to help with the AC not working as well.
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
and
https://www.2carpros.com/articles/replace-air-conditioner-compressor
Nov 5, 2017 at 1:04 PM
