a/c and blower not working
2005 FORD MUSTANG
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
BACC2005
Hello, I have a 2005 Ford Mustang. My Air Conditioning stopped working, and I think it may be a blown fuse or relay. Do you have a fuse diagram for this vehicle? I checked both fuse boxes, and both say to see owners manual, which I do not have (Bought the car used).
Jun 1, 2015 at 1:19 PM
HMAC300
  • 48,601 POSTS
Here is a guide a the fuse panel diagrams which show the fuse and relay that runs the blower motor.
and
Cheers
Jun 1, 2015 at 3:14 PM
HMAC300
  • 48,601 POSTS
also for blower check relay in smart junction box rh kick panel f1.2 and fuse 2.3 they should be marked inside cover
Jun 1, 2015 at 3:17 PM
BACC2005
Thanks for the info. The fuses were not marked and I don't have a manual so I just checked each fuse with a tester and found a blown fuse for the blower motor. Walla!!! Its now working.
Thanks again,
Don
Jun 1, 2015 at 7:22 PM
Hi there:
I had a quick question regarding the Fan Control Settings for my 2001 Mustang GT. Settings 1,2 and 3 stopped working all of the sudden. However, setting 4 works- which is the highest setting. Does anyone have any knowledge as to why settings 1,2 and 3 might have stopped working?
Thanks
Ed
Aug 29, 2020 at 12:26 PM (Merged)
MISTERMUSTANG
  • 20 POSTS
contacts on the internal part of the switch are not touching replace the switch i dont think that the fan in the car is multi tap meaning that i dont think there are more than 1 winding inside the motor so it must be the switch repplace it :D
