A/C blowing hot air
2001 SATURN SL2
246,000 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
CAWLADY1
  • 14 POSTS
Took it to a shop and was told compressor was bad. I replaced the compressor, dryer, expansion valve and condenser. Had the system vacuumed down and recharged. Worked for two weeks. Had it charged again and it is now it is blowing only cool air . What could it be?
Aug 8, 2019 at 3:14 PM
Welcome to 2CarPros.
If you had to have it recharged after two weeks, you must have a leak in the system. Take a look through this link first. It discusses possible issues with a system not working or weak.
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
Also, here is a link that explains how to find a leak:
https://www.2carpros.com/articles/air-conditioner-leak-detection
Aug 8, 2019 at 9:42 PM
CAWLADY1
  • 14 POSTS
Replaced the schrader valves and recharged the system. Compressor engages but no cool air.
Aug 8, 2019 at 10:29 PM
Welcome back:
If the compressor engages, then you have enough freon in the system that you should get some cool air. Have you checked to see if the blend air door actuator under the dash is working? Also, do you know the high and low side pressures?
Aug 9, 2019 at 7:56 AM
CAWLADY1
  • 14 POSTS
Thanks. I found a small leak in the discharge line. I will be replacing it and will let you if it works. Where exactly is the blend air door actuator?
Aug 9, 2019 at 9:57 AM
Welcome back:
That's your problem. The Freon is slowly leaking from the system. As far as a blend air door, this vehicle has what is called a mode actuator. It is under the dash, but now that I heard you found a leak, I doubt this is the problem.
I attached a picture for you to see the part.
Let me know if that helps and if you have other questions. Also, let me know if fixing the leak takes care of the issue.,
Aug 9, 2019 at 8:10 PM
CAWLADY1
  • 14 POSTS
Well, we thought we found a leak, not so sure now. It was under the foam piece on the hose but after taking off the foam. we think it was just excess from when it was filled. Do you think it's safe to put some Creon with dye in the system? The only thing in the system not replaced was the evaporator, all other components are new. Is there a way to test the blend door actuator?
Aug 11, 2019 at 5:54 PM
CAWLADY1
  • 14 POSTS
Well we thought we found a leak, not so sure now. It was under the foam piece on the hose but after taking off the foam, we think it was just excess from when it was filled. Do you think it's safe to put some freon with dye in the system? The only thing in the system not replaced was the evaporator, all other components are new. Is there a way to test the blend door actuator?
Aug 11, 2019 at 6:11 PM
Welcome back:
I don't see why it would cause any problems if you added a dye. Follow the link I mentioned regarding how to find a leak.
As far as the blend air door actuator, you would have to check and see if it is moving the door. Here is a link that explains some symptoms related to a bad one and in general how one is replaced:
Let me know if that helps and what you find.
Aug 11, 2019 at 7:37 PM
CAWLADY1
  • 14 POSTS
Would the blend door actuator be bad if the heater works fine? I also see a diode in the fuse box marked A/C diode. If this was bad, would that cause no cold air?
Aug 12, 2019 at 2:47 PM
Welcome back:
If you can change from heat to ambient temperature, then chances are it is fine. As far as the diode, chances are no. A diode is designed to only allow power to flow in one direction. Even if it is bad, it shouldn't stop power.
Aug 12, 2019 at 6:22 PM
CAWLADY1
  • 14 POSTS
Thank you. I'm at my wits end with this. The only thing that hasn't been replaced is the evaporator and from what I've read, that is really low on the scale as the culprit for no cold air. What are your thoughts?
Aug 12, 2019 at 7:11 PM
Welcome back:
I agree. What I suggest is to have the system vacuumed and then see if it holds vacuum. That way you can determine for sure if it is a leak or if something else is happening.
Could it be the evaporator, yes it can. However, that is a big job and I would want to be sure first.
joe
Aug 13, 2019 at 10:10 PM
