air conditioner
2004 JEEP GRAND CHEROKEE
70,000 MILES • 0.6L • 4 CYL • 4WD
JOSEPH1235
When I start car the air conditioner worked fine. At 2000 rpm's the air conditioner goes to defroster. Checked under hood for vacuumed leak did not find any. Any ideas?
Sep 15, 2016 at 3:32 PM
WRENCHTECH
  • 20,761 POSTS
I assume you must have manual AC as otherwise the actuator would be electric.
The mode selection is done through a series of air doors that are operated by vacuum. When there is either a partial or total loss of vacuum, the system will default to either defrost or on some vehicles, heat. Acceleration can also have an effect on the doors for the same reason.
Look under the hood for a small black plastic hose coming through the firewall. Follow it to the vacuum source looking for any breaks, cracks or leaks. Also follow any other lines that branch off because they may go to a vacuum reservoir (storage tank) and a leak there will cause the same problem. Using a vacuum gauge to determine if you have full vacuum at any given point is the best way to find it. You can cut into the line anywhere and splice it back together with a piece of vacuum hose. Find the broken line, you found your problem.
Sep 15, 2016 at 4:59 PM
