Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Chevrolet
Colorado
Climate Control
Air Conditioner
Not Working
A/C not blowing cold air
2005 CHEVROLET COLORADO
358,000 MILES • 3.5L • 5 CYL • 2WD • AUTOMATIC
JOSH PURVIS
MEMBER
1 POST
FOLLOW
My A/C only blows hot air.
Jun 29, 2020 at 3:51 PM
CERTIFIED EXPERT
Good evening,
Does the compressor engage when you command A/C?
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
Do you have a set of gauges to test the high and low side of the system? If not, you can rent a set at a parts store.
I attached a wiring diagram for you to view of the compressor. If you have a test light and volt meter, we can do some testing.
Check the fuses listed in the fuse block. Check them for power on both sides.
Jun 29, 2020 at 4:11 PM
