Do you know if the receiver drier is located in the passenger side front wheel well? It does not appear to be visible in the engine bay. Also does the compressor for a Beretta use a pressure switch which is mounted on the outside of it? If so, will the new compressor come with this pressure switch? I do not have the old compressor from which to switch parts. Sorry for all the questions. Thanks for any help you could give.
May 27, 2016 at 6:23 AM
