A/C not working
2005 BMW X3
194,000 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
MICKY LO
It's been 2 summers I've been without the A/C.
I've changed:
Compressor
Condenser
Pressure switch
dryer canister
High and low lines
Valves
Two thermostats
Blower motor
FSU
Control unit
When trying to charge the compressor does not active.
Shop manager says the system will not allow to input Freon. I do not know what next move should be.
Mar 21, 2020 at 5:29 PM
Okay. We need a little more info about why they say it will not "allow" Freon to go in. What happens when they try to charge the system? Most likely the compressor will not turn on until the level is high enough due to a pressure switch. However, if they have a scan tool they should be able to manually trigger the compressor and that will pull in the Freon. However, we need the detail about what happens in its current state.
Mar 21, 2020 at 5:47 PM
MICKY LO
Yeah, went another shop; they say I'll need a evaporator core. the system can't build up Freon and therefore compressor won't kick on. so I'm told. Cost $75.00.
Over the two summers my research did indicate that with the his particular model I have the evaporator core is a problem spot. Wish there was a recall where I can get this $2,000.00 job done at no cost to me.. car drives like a gem.
Mar 25, 2020 at 8:00 AM
Thanks for the update. It would be nice if recalls covered this stuff but unfortunately we don't get so lucky very often.
Thanks for using 2CarPros. Let me know if you need more info with this issue and I will be happy to assist. Thanks
Mar 25, 2020 at 11:15 AM
MICKY LO
Great, tell me with the BMW m54 engine can aftermarket air filters cause the service engine soon light to illuminate?
Mar 31, 2020 at 10:46 AM
Yes. Most any aftermarket parts can cause an issue. However, we will need a little more info. First, check the codes and see what the light is on for. Second, get the part numbers and manufacturer that made them.
The only issue is we need all this info posted on a new question. Unfortunately we are required to keep each post to one topic. Mostly so that others can find the answer to this question because they won't find it under and A/C question heading. Next is so that Google will post the questions for us when someone searches for this similar issue.
Thanks
Mar 31, 2020 at 11:57 AM
