Was this a problem with the old engine or only after the replacement? What year is the new engine? The first thing I would check is if the fuel pump is getting power. The Green wire is battery power and the Black wire is ground. The green wire gets power from the relay which is turned on by the PCM. If you connect a test light to the pumps power connection it should light when you turn the key to the start position. If there is no power to the pump then we can test at the pump relay using a test light connected to ground, with the relay removed there should be two pins in the socket with power. One will have power full time, the other with the key on. If you find those the other two contacts are the control ground and power out to the pump. If you connect the test light to battery power and probe those two pins, it should light on one pin if the wiring to the pump is okay and on the other pin if the key is turned to the start position. The relay should have markings on it showing the coil side and the switch side. If you have power to the pump but no fuel pressure at the engine then it could be a blocked line or the pump isn't moving fuel.
A quick way to check the system would be to go to the data link connection under the hood on the left side, find pin 13 which is a green power feed to the fuel pump and using a fused test lead apply battery power to that pin, that should send power to the pump and let you test easier. That pin should also get power from the pump relay with the switch in the start position as the PCM turns the relay on.
Oct 19, 2020 at 3:02 AM
