2 days in a row my battery has been completely dead upon trying to start the truck. Both times i charged the battery and its started fine. I took it to be tested and found out i have a 4.35A short or drain somewhere. Any suggestions would be greatly appreciated.
Battery test results are
Voltage 12.44
CCA measured 619
Rated 600
Temp 63F
Starter Test
Voltage 10.89V
Amps 210.9A
Time 781mS
Charging Test
No Load 14.15V / 10.5A
Loaded 14.05V / 9.6A
Ripple is 44mV
Voltage 12.44
CCA measured 619
Rated 600
Temp 63F
Starter Test
Voltage 10.89V
Amps 210.9A
Time 781mS
Charging Test
Ripple is 44mV
Nov 7, 2015 at 10:07 AM
