Seven lug rotors
2003 FORD F-250
307,000 MILES
BEASLEYTH
I have a E250 work van that needs front rotor/hubs. The VIN number is 1FTNE24W53HA69323. Tried to have them turned but they are to thin to get the warp out. All I can find is eight lug rotors. I even tried an online chat with Ford parts but they apparently did not have any more information available than I could find online. The van is all stock with original wheels. any help is appreciated.
Apr 11, 2017 at 6:02 AM
  • 34,308 POSTS
You listed "F250", then said you have a van. You also need to specify the engine size. You will find seven lug rotors on the Rock Auto web site, listed under "2003 F150".
Apr 11, 2017 at 3:05 PM
That sounds like the brakes they used on the F-150 Heavy Duty and supercharged trucks with the 5.4 in them. Take a look at the Ford BRR33 (used with four wheel ABS), Raybestos 66654R, ACDelco 18A904A or Ford BRR32(used with out four wheel ABS) and see if they fit. Attached picture is a BRR33.
Apr 11, 2017 at 3:38 PM
