First i installed the WRX (used about one year) clutch, pressure plate and flywheel and six speed transmission. i pushed the fork so the throw out bearing will click to the pressure plate but did not, after i installed everything i start the car shift it in gear the car will not move. i was thinking the WRX parts are not compatible with the STI transmission so i bought a new flywheel, cluch, pressure plate, throw out bearing after i installed the transmission bolts i pushed the fork same thing it did not click. could it be a bent fork?
Jan 5, 2018 at 7:38 PM
