Just put this motor in. changed coil pack, spark plugs, cam sensor, check all compression on cylinders, fuel pressure, check cams. replace timing gears and timing chains .re-time the motor, check valves and still nothing. it backfires through intake and exhaust and I can smell raw fuel. cylinder 1 120, cylinder 2 120, cylinder 3 130, cylinder for 140, cylinder 5 60, cylinder 6 150, cylinder 7 150, cylinder 8 145. so if anybody has something that will point me in the right direction I'd appreciate it.
Feb 10, 2020 at 5:29 PM
