Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Jeep
Liberty
Drivetrain
Transmission
Shift Solenoid
Replace/Remove
After replacing solenoid pack vehicle will not move
2003 JEEP LIBERTY
165,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
RICHARD TRAVIS BEAM
MEMBER
FOLLOW
42rle transmission. Replaced solenoid pack and now won't move and have to bypass relay to start.
Thanks
Jul 27, 2020 at 11:39 AM
CERTIFIED EXPERT
Good afternoon,
Were there any codes stored in the system for you to replace the solenoid pack?
Did it remove before the replacement?
https://www.2carpros.com/articles/automatic-transmission-problems
Did you get the fluid and filter changed?
Jul 27, 2020 at 1:27 PM
RICHARD TRAVIS BEAM
MEMBER
Yes, it was the code for faulty shift solenoid.
Yes moved, but once warm if it down shifted on a hill wouldn't shift back up.
Yes, did a fluid (ATF +4) as service manual said, also filter and pan gasket.
Jul 27, 2020 at 4:10 PM
CERTIFIED EXPERT
Okay, is the code still active? What is the code number?
Jul 27, 2020 at 5:11 PM
