How to change the fuel pump?
2020 CHEVROLET SPARK
132,077 MILES
GRACIEJ
And where is the fuel pump reset button on the car listed above LS model?
Jan 1, 2023 at 12:29 PM
SQM
  • 6,383 POSTS
If the fuel pump is not operational, it could be due to a faulty fuel pump relay, bad pump or wiring issues.
There is not a reset button for the fuel pump.
What exact issue are you experiencing?
Is the engine just cranking over but not starting?
One way to tell if it is a fuel related issue is by spraying starting fluid into the intake and trying to start. If the engine starts for a few seconds and shuts off, that tells you the issue is due to fuel.
Take a look at this helpful guide:
I have attached the fuel pump replacement procedure below.
Let me know if you have any questions.
Thank you.
Jan 1, 2023 at 9:25 PM
