Just bought my first Audi, and the A/C sorta blows cold, but not really. Decided to pick up a set of gauges from Amazon to see exactly what was wrong. Here is what I found:
Car off on low pressure side - ~70psi
Car off pressure on high pressure side - 90psi
Car on no a/c low side - 100psi
Car on no a/c high side - 100psi
Car on with compressor running low side - 80psi
Car on with compressor running high side - 120psi
Any idea on what exactly is wrong? Condenser from the outside doesn't look clogged, and the fan is turning on and off when the AC is turned on and off, but I was reading that the low side should be around 30-40psi with the compressor on and 200 for the high side. Is that correct?
Car listed above is a 2005.5.
Oct 23, 2019 at 5:12 PM
