Transmission swap?
2006 DODGE RAM
200,111 MILES • 5.7L • V8 • TURBO • 4WD • AUTOMATIC
MEGAN.TITUS
Will a 2003 dodge ram 4.7 transmission transfer into a 2006 dodge ram hemi 5.7
Feb 4, 2023 at 5:38 PM
It will fit, but there are things you will need to change. For example, the mounts are different. Also, you will need to replace the wiring harnesses, vacuum harnesses, PCM, and TCM for the new powertrain, the exhaust, and it will likely become a nightmare. Sorry, I don't mean to discourage you. I just want you to be aware of what you are getting into.
Nearly every time I have seen something like this done, there is always something that causes a problem. Usually, people get them running, but something will cause it to fail emissions or some other issue. Unless you are taking everything from one truck and reinstalling it into the new truck, it is difficult.
If you do this, I will try my best to help, so let me know.
Feb 4, 2023 at 8:24 PM
