We do not normally refer you to a shop. Instead we provide the information to allow you to decide if the repair is something you may want to do yourself or if you may want to take it to a shop/dealer.
In the case of a slipping transmission and the mileage you show it is likely that the transmission is due for a rebuild. As for a shop, any place that is able to handle a Ford transmission should be fine as that car is on the same platform as the Thunderbird and Lincoln LS and uses much of the same running gear.
Jul 3, 2018 at 11:50 PM
