two battery wiring starter
1994 MITSUBISHI PAJERO
44,335 MILES • 2.8L
TONY MCGOWAN
My car has two batteries on it. how do I wire the starter motor up?
Jul 5, 2017 at 4:26 PM
The two batteries should be wired in parallel so you still only have twelve volts. The starter is a twelve volt unit so there is no special wiring involved. Basically you have the same wiring as a single battery, just two connections for each instead of one.
I cannot find a good schematic of it as it was not sold in the US as a diesel just a gas model.
Jul 5, 2017 at 6:33 PM
TONY MCGOWAN
Both of the twelve volt batteries are ground to the car body. question is where do the two positive leads go for the starter motor? thank you.
Jul 6, 2017 at 10:55 AM
They both connect to the twelve volt positive terminal on the starter solenoid. Then there should be another cable from that to the main fuse box feed.
Jul 6, 2017 at 6:00 PM
