if there is sludge in your coolant there are a couple things to check here. try to figure out if it is engine oil or transmission fluid. it can be either, if it is transmission fluid then it is a broken cooler line in radiator if not have it pressure checked for a blown head gasket or intake gasket. If you see a sludgy/whitish buildup under oil cap then you probably have a head gasket problem or crack in head/engine block. more likely a head gasket however.
Jun 7, 2016 at 12:00 PM
