Hello all. Currently, I am working on the vehicle listed above. According to the VIN number, it came out with a 258 six cylinder but had a 304 V8 engine swap done prior to my purchase of it. Recently, I disassembled the vehicle down to the frame to inspect for any cracks in the frame. Fortunately all I found was it needing new motor mounts. I have reassembled it and am now currently having problems with it getting spark. I took pictures prior to disassemble and have hooked everything back as my pictures had and now I have no spark.
The main problem I have experienced is since someone did the engine swap prior to me, is the wiring is not color coordinated now. This vehicle was running prior to being disassembled but now I am having the no start issue.
I have ohm tested the coil and the positive and negative poles ohm out at 2.4 and positive and high output pole tested out at 11,500 ohms. From what I have read, I may have a bad coil. Any other help is greatly appreciated as to what could be causing my problems.
Jul 25, 2017 at 2:30 PM
