Have had never had a problem till now with this car. But one day the blinkers and gauges stop working. I found (2) 15 amp fuses have blown. These two fuses run the blinkers (Not Hazard; the lights blink in hazard mode) and the gauges to gas and temp and gear shift prompt. I replaced them once and everything worked okay till I turned on my head lamps, but also they blew in day light after having an expensive repair (distributor replaced) that did not cure the issue. I am going to take it back to the mechanic, but also replaced the head lamps two weeks before. Could I have used the wrong bulbs? What other common short would effect the blinkers and maybe even fry the distributor?
JamJells
JamJells
Apr 29, 2013 at 7:01 AM
