04 honda accord non vtec
1994 HONDA ACCORD
2,000 MILES • 2.4L • 4 CYL • 2WD
POS HONDA
My cam bolt came loose and let my timeing belt slip y driving down interstate and I was wondering if it's worth putting belt back on or is it likely that it bent valves or messed piston up and how could I tell without sending it to shop and putting more money in to that I'm sure the car is not worth if it's more then a few hundred
Jan 26, 2016 at 10:56 PM
MHPAUTOS
  • 31,937 POSTS
Fair chance that you may have a bent valve or two, only way to tell is to re set the valve timing and do a comp test.
Jan 27, 2016 at 3:23 AM
POS HONDA
K so can I just pull valve cover off and see if there messed up or is it more to it than that
Jan 27, 2016 at 3:27 AM
MHPAUTOS
  • 31,937 POSTS
More to it sorry, you wont see anything under the valve cover, its in the combustion chamber that the damage will be done, you need to re set valve timing and test comps or pull the head and inspect.
Jan 27, 2016 at 3:35 AM
POS HONDA
I watched a video on resetting the timing on a 94 honda and it showed two different belts to set but since the top one is the only one that came off do I need to reset both of them or just the one with the camshaft on it the one that came off
Jan 27, 2016 at 4:11 AM
