electrical problem with tail lights
1998 PONTIAC SUNFIRE
68,615 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
WORK A HOLIC
back lights all but runner lights don't work I have already checked fuses all good bulbs good changed the switch on the brake pedal changed the headlight switch on the steering wheel checked relays REE grounded the light back in the trunk checked plug and the light for corrosion cleanchecked also fuses for corrosion they are clean all so
Mar 15, 2015 at 4:33 PM
It sounds like you already did a lot. Have you checked grounds? Have you tried tracing the wiring to see where power is lost? Is there power in the fuse box?
Mar 16, 2015 at 5:27 AM
