How to Retrieve and Read Suzuki OBD1 Codes
 The following is how you can retrieve and read trouble codes for Suzuki vehicles before 1996, OBD1 system.
Let's Jump In!
 Begin by accessing the fuse panel on the drivers side, at the lower left corner of the fuse panel there is an empty fuse holder, install any fuse, the check engine light will start flashing once the ignition key is turned to the on position. Count the number of blinks, this will be the first digit of the two digit trouble code, there will be a short pause and then the second digit of the code will be displayed. For example if the check engine light blinks five times and then pauses, blink four more times, the code number would be 54. After repairs have been made the trouble codes need to be cleared. To do this disconnect the negative battery cable for three minutes and reconnect.
Diagnostic Trouble Code Definitions
Code 12 System normal
Code 13 Oxygen sensor fault
Code 14 Engine coolant temperature circuit fault, high voltage
Code 15 Engine coolant temperature circuit fault, low voltage
Code 21 Throttle position sensor (TPS) circuit fault, voltage high
Code 22 Throttle position sensor (TPS) circuit fault, voltage low
Code 23 Air temperature sensor circuit fault, voltage high
Code 24 Vehicle speed sensor circuit fault
Code 25 Air temperature sensor circuit fault, voltage low
Code 31 Pressure sensor circuit fault, voltage high
Code 32 Pressure sensor circuit fault, voltage low
Code 33 Mass air flow sensor circuit fault, voltage high
Code 34 Mass air flow sensor circuit fault, voltage low
Code 41 Ignition signal fault
Code 42 Crank angle sensor circuit fault
Code 44 Idle switch of TPS, open circuit
Code 45 Idle switch of TPS, shorted circuit
Code 51 EGR system circuit fault
Code 52 Injector fault
Code 53 Ground circuit fault
Code 54 Fifth gear switch circuit fault
Code 71 Test switch circuit
Questions?
Our certified technicians are ready to answer car repair questions for free. We hope you saved money and learned from this guide. We are creating a full set of car repair guides. Please subscribe to our 2CarPros YouTube channel and check back often for new videos which are uploaded regularly.
